id10t_error
I got too many customers and each one uses some wacko unknown VPN software...
Any good ideas on creating a VPN client software Virtual Machine and securely route traffic to and from the VPN VM and Automation VM's?
I can just create a VM and install the client VPN software with two network adapters, one in bridge and one as host-only.
I imagine each automation VM would have a bridge and host-only network adapter. When not directly connecting to the PLC/HMI via ethernet at the panel, I can disable the bridge adapter within the VM, however, I would need some mechanism or static route in my host or new VPN VM to route the automation network traffic through the host-only, to the VPN VM, then out the VPN VM bridge.
This has to been done before... any ideas?
