N.O stop N.C start
Ryan
Mar 2004
Does anyone know how to design a start stop station using a N.O stop and a N.C start for an electrical diagram, not a plc diagram
Easy, just use interposing relays to FIX the dyslexia problem... :D
| START PB |
+---]/[--------------------( CR1 )--+
| STOP PB |
+---] [--------------------( CR2 )--+
| CR1 CR2 |
+---]/[---+---]/[---+------( RUN )--+
| RUN |
beerchug
-Eric
| START PB |
| STOP PB |
| CR1 CR2 |
| RUN |
beerchug
-Eric
Your third rung has CR1 and CR2 reversed, but you have the right idea.
This is a pretty off-the-wall question.
Ah, yes it is Jimbo! I got confused because this is simply the WRONG way to solve the problem... ;)
beerchug
-Eric
Is this an excercise in a class ?
I ask because it is a very unusual combination, and there are problems with the safety:
No power to the STOP button: Device will continue to run and cannot be stopped.
No power to the START button: Device will start immediately !
Sounds like your teacher said something like:
"NO for start and NC for stop is the normal thing, what would happen if the reverse was the case ?"
You should answer something like "That would be very dangerous, Sir.".
It is quite common for the STOP button to be NC because it increases the safety in most cases.
Hello I am trying to make a program work with a sqo instruction .The process has 5 steps ,and a starting step of zero.There should be 8 sec...
17
1,057
Good morning to everyone on the forum and happy new year. I'm trying to use the following functions in sysmac studio, because I need to enable one...
327
Good Morning , I would like to start a Powerflex 525 with a N.O. Start Pushbutton , and when the N.O. Start Pushbutton is released I would...
1,671
Hello, I am trying to detect when the PLC changes from STOP to START mode. This can be considered an edge case scenario, but I would to analyze...
1,566
Hello Everyone! It has been a while since I used the method of drawing a state diagram, converting that to Boolean algebra, and translating that...
2,969
