NAUAS fault in ISTACK S5
volvo123
Mar 2010
Skövde
Hello!
I have a problem with the PLC going in to Stop-mode and the only thing I can find that seems to be wrong is NAUAS (power failure in central controller) in the ISTACK. What does it mean and what can be the cause?
The fault bits in section 1 are fault bits NAU(AS) means power failure check power supply & boards are correctly slotted in frame, this probably means that the PSU is faulty or the processor card has dicky pins or sockets on backplane or even a dry joint on the plugs/sockets try cleaning the boards (processor /psu plugs & check for bad solder joints or if you have a spare psu try replacing it.
Hi!
We located the fault. It was a PSU in a decentralised PLC rack, we replaced it and after that no problem. Thanks anyway :)
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
44
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
93
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
144
Hi, Experts: We have 20 + years old GE PLC series 90-30 stop running (the run led not on and battery led not on) and HMI showing that "PLC has...
198
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
117
