need a cd or solution
joesph
Sep 2015
florida
Hey all. The facility where I am at is running RSView me station version 4.00 (cpr7). We had the hmi computer go down. I have all the other cd's to install except this one for the ME station. Does anyone know where I can get a copy. Rockwell says they do not distribute this older version anymore. I would like to use this same version. Does anyone know if I can not find one if I need to upgrade logix5000, studio, linx, and me station all together to get it to work?
While I personally would take this as an opportunity to upgrade FactoryTalk View, you should push back harder on your RA office.
Every sales office will have old revision disks or hard drives. Not keeping your RSRevs DVDs or hard drives is unthinkable for a Solution Architect or Technical Consultant.
The download site only goes back to version 5.0, so I do believe that they don't "distribute" older versions.
Our plant has a network repeater station located in a field with two ProSoft RLX2-IHG network radios for connecting our plant network to a well...
2,415
I have a micrologix 1100 and a LVDT displacement sensor. The sensor can measure from 0 to 2in. It has 0 to 10V output and I was going to use it...
1,339
Hi All, I need help on this CPU Error Code 3303. I got 2 PLC controller mounting side by side beside power supply. One master & another is an...
1,162
Hi I have this two program in Rslogix 5000 and I need your help to solve ever one individually A and B. Please see the attachment. I need only the...
5,655
1,209
