need cheap parts ??????
drewcrew6
Apr 2002
allentown, Pa
418
Maybe someone has an idea on this.
I'm looking for a 24vdc solenoid with actuator about a 2" stroke.
But I need the pull to be relatively slow (able to watch the movement) possibly oil or spring dampened? Preferably spring or a well sealed unit, it will not be accesable when in service.
Does not need a whole lot of pull just to shift hvac dampers.
I know I can buy motorized dampers but manual dampers are all installed already. And I'm just looking for a way to tweak the damper not full temp control.
It is a home project so cost is a major issue.
Thought about car lock sol 12vdc but they snap to hard.
Drewcrew6
Well, you want cheap, and you've already considered door lock controls, take that thought a step further and consider a power window motor. They move relatively slow, and can be found in a junk yard. Another alternative, early to mid '70s GM (Oldsmobile for certain, maybe others such as caddalac and Buick) used a threaded shaft arrangement on a motor for the door lock (sort of like a "stripped down" linear actuator). While you're at the junk yard, check out the power seat workings, one of those may fit your purposes.
I like that site !!
Leaning towards the mini stepper motors, has anyone gotten one?
Drewcrew6
now if i could find a cheap 240 volt 5hp motor for my compressor?
Years ago I bought a stepper kit from ALL just to learn about how they work. The one I got was operated by a pot, not a pulse train.
Since car motors are mentioned, don't forget the windshield wiper motor. Lots of torque, slow speed, a nice crank arm, easy to mount and when the park relay is engaged, a repeatable stoping position.
I'm thinking about ordering 3-4 different motors from them to use in the 5' RC boat I'm tryin to get working....can't beat the price since I can get (2) of all 4 motors and only spend about as much as I would on a single normal RC motor
And if you use a car device (window, wiper, or whatever), put the two in series, with the mechanicals properly situated, and you can still use your 24V original source.
I had a PLC class 7 years ago and I want to relearn it by building my own PLC. I have been collecting modules, CPU, power supply, and rack. The...
17
5,531
Hi there guys, I have been playing with demo of Ignition SCADA and have it reading and writing happily with my S7-1200. The trouble is my boss...
6,148
I'm looking to start practicing programming touch screens, currently I have an AB micrologix 1200 along with an analog module, Is there any good...
28
10,598
Hi Everyone, While searching on the internet, I found out about this forum. Looks like a great gang that is really helpful to others. Hopefully...
20
7,488
194
