Need explanation with spool valve symbol
mikas_m
Feb 2007
ck
154
Dear atomation experts,
Can you please help me by explaining how spool valve with the attached symbol works?
I know that spring (b) returns the spool valve into initial position (P->A, T->B).
When the el.magnetic coil is energizedm, then the connections are: P->B, T->A).
When voltage is not present, the spring returns the spool in initial position. This Q is probably a symbol forI manual oprations.
When it is possible to use Q?
This is very uncommon symbol and I don't know where this can be applicable.
Thank you.
It is just a manual override for the valve to allow manual checks of operation.
It can by useful if you are having problems with the valve not appearing to change position. Using the manual override it can help you diagnose if the fault is electrical or mechanical.
Thank you guys, very helpful. I'm now sure it's a manual override.
There is a number on the spool valve: 4WE6D51/AG23xxxx(unreadable), but I cannot find datasheet for it.
There is however one interesting thing. if I push it manually, I would expect the spring to return it to initial position, but this is not happening.
How to test if the spool valve is working (for example, what is active resistance to be expected If I measure with multimeter)?
I know also it is for max 31.5 MPa. What would be appropriate equivalent?
Thank you
You may have to contact Rexroth for the datasheet/info as that doesn't appear on their website.
31.5MPa is 315Bar or about 4500PSI
Hello all, A little background. Our organization is exploring using the Siemens S7 1500 PLCs in the future. We are an Allen Bradley's house...
1,968
Hello automation experts, I kindly ask your help about the pneumatic valve shown in the attached image. The valve is 3/2 which means it should...
2,936
Hi. Im having problems understanding hw and gsd files. Hw is the hardware itself and gsd is what? What about installing hw files from siemens...
2,372
I am newbie in S7 and PLC and i am trying to learn analog processing in S7. I have got an example, which raise some questions. In the following...
6,852
Hi guys, in literature I found term "tripping". I dont know what is it but I know it has something to do with circuit breakers. For example...
3,387
