Need help on 1769-HSC card and the shaft encoder?
wendaiyu
Jun 2014
toronto
87
Hi, guys, how going?
Could you give me a hand on my small project?
One part of the project is that we want to use a shaft encoder (part number: 15S-20M8-0360NV1R3PP-J00-S1) to monitor the height of the blade.
We already finished 1768-L43 controller and I/O cards configuration. Then we simulated the program and it worked well.
I got 1769-HSC card today.
Could you tell me how to wire the card to/from shaft encoder?
How to set up, program this HSC card in Logix5000? Like if the encoder is on clockwise rotation, counter number should be up, otherwise, the number should be down.
Thanks for your help.
Hello, I am a bit familiar with PLC programming, but I've never dealt with servo drives before. I am having a hard time even establishing a comm...
1,380
I am new to compactlogix 1769 L30ERM PLC. when I was upgrading firmware to version 30 through control flash flowing error came. it is; and also...
3,040
Hello I am new to setting up communications between my PC and my 1769 L32E proccessor. I have been trying to figure this out but no cigar...
4,801
Hey guys Hardware: 1769-L32E CPU 1769-PA4 Power Supply 1769-IA16 Input Card 1769-OW16 Output Card 1769-IF4XOF2 Analog Card I just built a PLC...
4,399
Hi folks...I need some help getting a 1769HSC configured correctly. Here is what I need, in specific: I will need to use a directional counter...
1,536
