OkiePC
I have a customer with a valve that has limit switches and what I think is a rotary potentiometer for position feedback. The analog sensor gives a a very flaky reading (4-20mA input to a Micrologix 1400 via 1762-IF4).
Both of the limit switches are froze up. This is in a vault that is covered but exposed to moisture and temperature extremes.
I was thinking about using proximity sensors for the end limits but it might make more sense to use a laser distance sensor or something similar and just do away with the limit switches. If I can get a very repeatable analog sensor I think this could work well.
I think the object on the stem is made of stainless steel so a long range inductive prox could work for limit switches. I believe the travel range of the stem is around 4 inches, but I am not certain of that. The only laser distance sensor I ever worked with was something like ten meter range and in a relatively clean climate controlled setting.
Tell me what you think:
