Need Print From TD-200 Display
Nauman
Jul 2004
Karachi , Naval Colony
Dear Sirs,
How can we get the temperature values from printer using communication b/w TD-200 (Rs232c) - Printer (Lpt)while the temp values are displaying on td-200.
"The PLC we are using is Siemens 224 & program for it is Step 7 200 "
Regards
Nauman
There is no way to communicate directly between TD200 and your printer.
You could transmit the value throughout the CPU if you have an additional free CPU port. Otherwise you would require a CPU with 2 ports or a EM277 extension module where you could connect your TD200 instead.
For transmission you would use the Freeport XMT instruction.
To convert the values into ASCII format following built in instrcution are available ITA,DTA,RTA,HTA.
A PC/PPI cable to convert RS485/RS232 is required.
P.S:
There is no way to use PPI and Freeport on same CPU port,
as long you had a external PPI Master(TD200) in your network.
Hi, I just recently had to add some safety features to an older machine. I made some changes to the PLC 2 logic for the new features. I don't...
1,586
Hi all, Anyone here that stil uses NT suport tool for Omron hmi. I can't get my version running on my laptop, so maybe someone here can make a...
3,565
Please print to pdf I dont have the software. Thank you Where are the comments stored?
1,806
How do I print old dos program to windows need to print old Allen Bradley PCIS SLC 100 PROGRAM.
5,418
61
