Need Some Programming Help
DanielM
Apr 2009
Racine, WI
New here name is Dan and I need some programming help.
I use rslogix500 plc is a micrologix1500 I have a HSC tied to it and a 845H encoder. I have all this installed on a coil cradle straightener along with a VFD what I would like it to do is the material is in the CCS and the encoder would keep track of the legnth being feed through it when it achieves the proper legnth the plc would stop the drive and send a output signal to the chopper press. If anyone has done something similar to this and you have a sample program to share that would be great.
Thanks,
Dan
I did something very similar, a sheet metal feed/cut system, and a drywall stud feed/cut.
Both were on Omron PLCs, so if you think you could translate to whatever you need, I could send them.
I use rslogix500 plc is a micrologix1500 I have a HSC tied to it and a 845H encoder. I have all this installed on a coil cradle straightener along with a VFD what I would like it to do is the material is in the CCS and the encoder would keep track of the legnth being feed through it when it achieves the proper legnth the plc would stop the drive and send a output signal to the chopper press. If anyone has done something similar to this and you have a sample program to share that would be great. Thanks, Dan
OK we need some mechanical paramaters
What is the material steel brass etc?
What are dimensions of material being uncoiled?
Will the dimensions change?
How fast are you feeding it to chopper
What is fastest cut rate on chopper
What is minimum length you want to cut
What is maximum length to cut
Dan Bentler
If you want to send it that would be great I think I could get some useful info from it.
Thanks,
Dan
Dan Bentler
The widths would change and the legnths could be +/- .250" the material is steel the chopper is a old 150 ton stamping press that we converted to bolt in the chopper die. I have the encoder mounted to the final drive roller so the roller has tension and that's how I would keep track of the legnth. I have a 4 Pos SEL SW so I will have 4 legnths that need to be obtained 10" 36" 48"and 96" the chopper can go as fast as needed to keep up with the CCS. There is a VFD so I should be able to feed material as fast or as slow as needed
Thanks again,
Dan
Hello there, I'm practically new to the PLC world, I'm quite familiar with Siemens TIA Portal but I'm currently tasked to program Schneider PLCs...
1,875
Hello, I’m currently working on a project using a unitronics samba plc, I need to create a program with a touchscreen start and stop button, that...
2,281
Hello Experts, please help me out on programming. inputs tank full float switch tank empty float switch outputs inlet solenoid drain solenoid...
2,459
Hello i need one of you fine gentlemen to help me with some ladder logic. I'm brand new to PLC's and admire you guys, i'm a long time stalker...
16
5,094
I work for a small town company and we have been growing, they recently bought a few Panasonic performarc robotics that have manually operated...
1,423
