Mauro_Autintrol
Why hello, world!
I am in the need of showing a registry from a ControlLogix, Through Factory Talk Site Edition to Excel. I had some issues at first trying to make that registry register ONLY when a Tag on my controller went from 0 to 1, after I managed to make that possible I run into another problem, I needed that class to be running all the time so al my variables are set and declared waiting for that tag on my controller to change from 0 to 1 in order to register.
I did all my code inside the class of a buttonm something like:
Private Sub Button2_released()
***code***
End Sub
So, in that case the class only runs when I pressed the button in my factory Talk Site Edition application.
Trying to make my class run all the time I changed it from the button to the display class, which is always active in the factory, being something like:
Private Sub Display_AnimationStart()
***code***
End sub
Didn't work. I also try changing the class from private to public, didn't work either.
I'll leave the code attached if you want to take a look.
***code***
End Sub
***code***
End sub
