NEMA4X enclosure with viewing window
Charbel
Jan 2012
Beirut
307
Dear,
I am searching for NEMA4X enclosure with viewing window, but I could not find it, I am not sure if it can be easily found.
This enclosure will be located outside and will be housing some controllers with LCD that is why viewing window (glazed door, for example) is needed.
really appreciate any help on this issue,
thank you!
Charbel
dear, I was wondering concerning how much IP66 and NEMA 4X are equivalent, since NEMA4X calls for corrosion protection and IP66 doesn't. Kindly...
1,834
I need an enclosure for wifi access points that will be outdoors. The antennas will mount outside the box but everything else inside. Standard...
157
Hello all, I have a question and would like a few opinions if possible. 5x 480 outlets control 5 machine. I want to run them through a contactor...
181
Looking over the technical data for a PowerFlex 755 & noticed they specify a minimum enclosure volume for their drives: (1)When using a circuit...
551
We am planning to build an electrical enclosure on the manufacturing line. The only concern is to prevent dust from getting collected inside the...
2,066
