Netlink adapter MPI-LAN Hilscher
dmkar
Jul 2007
at home
29
I bought the netlink adapter MPI-LAN from Hilscher. This together with the KepServerEx for Siemens. I can configurate the KepServer, i can put an IP-adres in the adapter, but they do not want to communicate. The IP adres in the adapter is accepted, i can 'ping' to it.
How can i make them communicate?
I have 2 Siemens S7-300 PLC's, a PC with a standard ethernet card, a switch and the KepServerEx.
Thanks.
I dont know either the Hilscher adapter or KepServerEx.
But I am taking a guess at that the problem ha to do with the rack/slot assignment. You have to specify rack and slot as well as the IP address.
Normally for an S7-300 it is rack=0, slot=2.
I know for some of these 3rd party ethernet/MPI adapters, that they use a "trick" to specify the MPI or DP station address. It consists of combining rack and slot in a special way to specify the MPI/DP station address. Look in the manual !
Thanks, but this is not the problem.
The MPI adres, slot, rack, etc are assigned. It must be something with the driver.
Is the IP addresss of the Netlink and the IP address of the PC that the server is running on in the same subnet. If it is not then you will not be able to get a connection.
Are there any errors posted in the server event log? if there is a configuration issue then that could be a problem and you will get an error in the event log.
Did you make sure that all the MPI addresses used are unique, i.e. the master MPI used by the server does not conflict with those used by the PLC or netlink adapter?
What is the version of KepserverEX that you are using?
Thanks for the replies, the MPI-adres of the netlink adapter was the same as the PLC. Now everything works fine.
Hi All, I'm using NETLink PRO Compact by HelmHolz to connect a PLC Simens s7-300 and it works good. This means I can go online on to the plc and...
3,846
Hi I wonder about som technical aspect regarding netlink communication to CPU 314-2C DP. When i set my adress 0 in PG/PC interface (the same as...
1,355
Hello, I have the NETlink USB compact. It works perfectly fine when i use it on a Siemens 300 PLC. But it won’t work with the Beckhoff 315 PLC. I...
2,112
Hello all can any one tell me what is the difference between 1.cp 5512 vs netlink pro? 2. Which is more superior? 3. How netlink differ...
3,577
hello problem on Netlink Pro Eth. i connected the Netlink to Switch and from there to 2 PCs. i am able to get the data on 2 PCs. Now wants...
2,446
