NetLink Pro and OPC Server
S7Guy
Nov 2003
Dayton, Ohio
1,250
Ok, I've been using a Softing NetLink Pro MPI-Ethernet adapter, and it works great. Now, I want to use it with an OPC Server. I tried the evaluation version of the latest DeltaLogic OPC Server that is supposed to be written specifically for the NetLink, but it has completely locked up my computer 5 times. I've installed, rebooted, uninstalled, etc. I give up.
So, has anyone used this specific adapter with a different OPC Server? I guess my next option would be to buy the Heimholz NetLink adapter (a different company) and use it with Kepware, but I'd rather use what I have.
Have you tried Simatic Net ?
Seriously, I once asked Deltalogic (I think Deltalogics and Softing's are the same) and they said it should work.
As far as I remember, they said that it would work with Simatic Net if you used a special way by combining "rack" and "slot" to specify which MPI address to connect to on the MPI side.
Hi All, I'm using NETLink PRO Compact by HelmHolz to connect a PLC Simens s7-300 and it works good. This means I can go online on to the plc and...
3,842
Hello all can any one tell me what is the difference between 1.cp 5512 vs netlink pro? 2. Which is more superior? 3. How netlink differ...
3,575
hello problem on Netlink Pro Eth. i connected the Netlink to Switch and from there to 2 PCs. i am able to get the data on 2 PCs. Now wants...
2,446
Hi I wonder about som technical aspect regarding netlink communication to CPU 314-2C DP. When i set my adress 0 in PG/PC interface (the same as...
1,353
Hello, I have the NETlink USB compact. It works perfectly fine when i use it on a Siemens 300 PLC. But it won’t work with the Beckhoff 315 PLC. I...
2,112
