Networking 2 PLC's on different subnets
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello All. I need to network two CompactLogix on different subnets. One is 192.168.1.22 and the other is 10.10.30.15. Since I have to bring a system down to do this, I would like to get some advice beforehand. I was thinking it would be a simple matter of doing this:
but realize they must be on the same subnet for this to work. Any ideas as to a quick and dirty way to accomplish this? Hopefully this is enough info. Thanks
There are many ways to skin the cat but getting a router and setting up 2 VLANs with inter VLAN routing would be the cleanest.
As posted earlier NAT could work but that's not the typical use case for NAT.
You don't want to change the subnet because likely with what you have you would need to change it on a lot of other devices and also setting the subnet mask large enough to compensate the subnets you have would likely gain a lot of other traffic you don't want or need and may cause you problems.
Hello All, I have two CompactLogix that I would like to network together however, they have different IP subnets. Is there a way to connect them...
4,451
I have a question about IP addressing and Networking. I have a PLC with following IP address 10.1.0.120 this is an static PLC PLC is working like...
2,025
Hello all. I have a system with 4 different machines, each has their own PLC. I also have a RC in this subnet also. I created a server PLC that...
464
Hi Every one I want to hookup the 10 numbers S7 300 PLC CPU on MPI Network . CPU,s are running on 10 different machines with 12 " HMI on each on...
2,122
I have searched the forum, It looks like some people are doing a similar thing but I still have some questions. I have a number or PLC's, most...
4,742
