Networking 2 PLC's with different IP's
So as discussed, a router or a NAT device is probably the best way to go here.
Consider that a router will connect the two networks. It could potentially allow any device on either network to talk with devices on the other network. Digging into the configuration you would be able to limit which devices can traverse the network, but that can get tricky on a router. I believe the default would be everyone can talk to everyone, and then you go from there to start limiting access. Your IT group might also have an issue if you are adding a router that could potentially touch their enterprise network.
A device like the 1783-NATR might be a little easier to setup to allow only specific devices to be visible to the other network. It starts with no one can access, and then you add mapping to allow access. I think that device is limited to 32 mappings.
OG
Hello All. I need to network two CompactLogix on different subnets. One is 192.168.1.22 and the other is 10.10.30.15. Since I have to bring a...
1,783
I have a question about IP addressing and Networking. I have a PLC with following IP address 10.1.0.120 this is an static PLC PLC is working like...
2,010
Hello all. I have a system with 4 different machines, each has their own PLC. I also have a RC in this subnet also. I created a server PLC that...
462
Hi Every one I want to hookup the 10 numbers S7 300 PLC CPU on MPI Network . CPU,s are running on 10 different machines with 12 " HMI on each on...
2,121
I have searched the forum, It looks like some people are doing a similar thing but I still have some questions. I have a number or PLC's, most...
4,740
