Networking question
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day all. If I would like a PLC on one LAN to communicate with another PLC on another LAN, is that possible without using a router? For example: PLC1 is on 192.168.1.x and PLC is on 192.168.0.x. They are both CompactLogix. Thank you
Possible: yes.
Without a router: depends on your sub net mask
Will I need to change servo amps and robot also or only the 2 PLC's?
It depends on if these need to talk to a PLC on another subnet or not.
Basically think of pairs of devices: should they talk to each other without a router? If yes then they both need to be on the same subnet.
For example, the robot talks to only one plc, all the servo drives and vfd's only talk to one plc. I just need the two plc's to talk to each other.
.. I just need the two plc's to talk to each other.
Then expand mask on both PLCs. Don't expand it more than you need.
All I said above is under assumption that that both PLCs are on the same VLAN. If they are on the separate VLANs then you must have routing enabled.
So the quick and short of the situation is that I designed an axle press that was sent to one of my company's other facilities. That facility just...
19
4,262
Hi Y'all, I know next to nothing about network communication. My question is I have a network that I use to access the line PLC's, but a lot of...
1,706
Hello, I currently have a PLC network that communicates on a 192.168.1.x address 255.255.255.0. I am looking to add a few other machines to the...
19
4,550
Hey guys, got a question, I have a Micrologix 1500 an Automation Direct C300 and my laptop. I would like to be able to plug in while running all...
1,680
We had a security audit for our bank 6 months ago. We are now doing a follow up audit. Since the first audit they added a wireless access points...
2,033
