New issues with PV 600 communications
bright676
Nov 2012
va
494
I have a PV 600 2711-K6C5L1 and a 5/04 and I had wanted to hook up another PV to it but ran into a problem with a off brand part that has the same p/n of the A/B product I need but does not have the same functionally of the genuine A/B part that I need.
Any way, back to my issue. I am just going to go with using one HMI. I would like to use one cable to program my PV 600 and my 5/04. I dont like all the disconnecting and moving them around.
I have been looking in the PV user manual and I dont see the set up that I want to use.
Does any one have any ideas?
Thank you
See pdf below page #6. Just replace the micrologix with your SLC. Use a 1761-CBL-PM02 cable between the AIC+ and your SLC.
Hello, I've recently tried to upgrade my PLC controller from a L72 to L84ES and everything seemed to work, all buttons and screens as far...
2,639
I have a used PV600 I plan to use to replace the one at my customer's that lost it's memory. There is a program in it, so I thought I'd practice...
1,317
Currently have an old PV 600 hooked to the side port of a ML1500. Originally the driver in the Panelview was listed as - -Serial-DF1...
1,594
Until recently, the PVP700 and PVP1000 projects were the same 600x480 resolution. The new PVP1000s are now 800x600. Has anyone been challenged...
1,399
Hey guys, I have probably gone through 3 different forums looking every type of answer anywhere close to what I have, and I just cannot find a...
1,983
