New MicroLogix 1500 vs Existing SLC 5/04 + 1747-SN + Flex IO
I've worked on a few strapping machines in my time, including monitoring the PLC program for the strapping head. I've never seen an instance where online programming changes were necessary or advisable for the strapping head.
Because the same RSLogix 500 tool is used to program both SLC and MicroLogix 1500, and because the base + CPU only adds two part numbers to your inventory, I'd recommend going with the OEM's plan of a controller just for the new head. They can program, test, wire, and ship it as a unit.
There may be a high-speed counter or other reason for them to want to use the MicroLogix 1500. The onboard I/O is an order of magnitude faster than a RIO link.
Thanks for the feedback Ken. FYI, we already have a HSC card in the existing SLC for the steel head so it can be reused if neccessary although it looks like all they have is discrete IO in the new system. I'm double checking on that.
85
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
106
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
921
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,210
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,431
