New S7-300 project problem with Profibus
idell
Nov 2009
Bucharest
97
Hello,
There is a problem with profibus comunication on my new project, CPU dosen't "see" profibus slaves. As you can see in attached picture, with diagnostic profibus in Set PG/PC interface slaves are present. The project is new, the empty OB1 is only downloaded. In diagnostic buffer of CPU no one information about missing slaves.
10 and 12 are not available at all.
11 probably isn't connected to the partner or the partner isn't configured properly.
13, 14, 15, 16 probably aren't configured in the drive setup.
edit: The diagnostics buffer will only report problems that are relevant to the user program. Since your OB1 is empty there will be no entries.
Have you checked your cabling to make sure it is correct and that you have a resistor at each end switched on or the necessary dipswitches if a drive is at the end of your network?
Regards,
Barry
Hi all, I'm quite new to this. Although I have some IT knowledge this is different stuff. I'm breaking my head over the following. I have SF and...
1,763
Hi, I have a few questions in relation to a new project I must design. Sorry if a little vague on existing hardware, but it's all the information...
14,035
Hello. I have a question regarding a PLC siemens with Profibus and drivers Brand rexroth (ECODRIVE03), would add an HMI brand siemens to the...
6,363
Hi All, I have noticed that when I Archive my Multi Project it will only allow me to do it to my PC first (anywhere ie desktop or any directory...
1,599
I'm using a direct cable to its port. It says that's using protocol DH485 but when I try to download this project from PanelBuilder32 my only...
2,250
