ToolGuyFred
leitmotif said:NONE. The only force bringing both bullets down is gravity. It is constant so both bullets stay in the air the same time. The only thing you change by changing angle of gun is distance.
Dan Bentler
Not so. When the gun is fired horizontally, we only have a horizontal component to the vector of the motion of the bullet at the moment it leaves the gun. The lack of a vertical component means it will hit the ground at the same time as one which is dropped. If the gun is pointing upward then there is a vertical component to its motion which must be taken into account (that's why the bullet goes further).
