New Year's Eve puzzle
Steve Bailey
Apr 2002
The boondocks of Western Massachusetts USA
8,593
Kicking Tarik1978's puzzle
http://www.plctalk.net/qanda/showthread.php?t=127694
up a notch:
Using the keys available on the Microsoft calculator in scientific mode create an equation to make this correct for all integer n from 1 to 9.
1 1 1 =n
2 2 2 =n
3 3 3 =n
4 4 4 =n
5 5 5 =n
6 6 6 =n
7 7 7 =n
8 8 8 =n
9 9 9 =n
You must tap the applicable numeric key on the calculator exactly three times for each of the 81 solutions.
If it's stupid the what do I say about my math skills, I realized after sending my solution that I used four key strokes. But then again I don't have microsfot calculator on my blackberry.
I didn't mean you can't tap any of the other keys on the calculator. You can use as many non-numeric keys as often as necessary.
Example:
7 7 7 = 7
If you want to use \/7 * \/7 + ? = 7 for your equation you'll need to find an expression that contains the numeral 7 and evaluates to zero.
If you want to use (\/7 * \/7) / ? = 7 you'll need an expression that evaluates to 1 using only a single instance of the numeral 7.
Do you have to press the '=' button to get the result?
interesting question. I would suppose not, but it does say "an equation," so maybe it is necessary.
I only needed + and = and / (divide)* to do 7 of the 9 n values for all source numbers, and added the [x] key (times; multiply) for one of the rest and the [-] key for the other.
* Update:. Whoops I forgot divide in the first attempt at this post.
I clearly did not understand the puzzle and probably still don't.
n is 1-9 for every case? So 1 1 1 = 1or 2 or 3..... 9 ?
1 1 1 = 1 example solution 1 * 1 * 1 = 1
2 2 2 = 1 example solution (\/2 * \/2) / 2 = 1
3 3 3 = 1
etc
8 8 8 = 1
9 9 9 = 1
1 1 1 = 2 example solution (1 + 1) * 1 = 2
2 2 2 = 2
3 3 3 = 2 example solution 3 - (3 / 3) = 2
etc
8 8 8 = 2
9 9 9 = 2
1 1 1 = 3 example solution 1 + 1 + 1 = 3
2 2 2 = 3
3 3 3 = 3 example solution (3 * 3) / 3 = 3
etc
8 8 8 = 3
9 9 9 = 3
etc
1 1 1 = 9
2 2 2 = 9
3 3 3 = 9 example solution 3 + 3 + 3 = 9
etc
8 8 8 = 9 example solution 8 + (8 / 8) = 9
9 9 9 = 9
Solutions (acceptable) so far from drbitboy and LD[AR2,P#0.0] that take advantage of the quirks of the calculator operation. Nobody has yet attempted a complete set of equations in the form outlined above.
I can relate to that. Then again I am recovering from sickness so may also be attributed to that.
I have an actuator operating a clamp that requires PLd/SIL3, I’ve seen some SMC double valves with feedback, but they are described as dump...
2,363
we have lost the HMI Panel View source file (.apa) we do not have back either. we have only .PBA file. can some one help how to get .apa source...
1,147
We have many CISCO and STRATIX switches in our process network. The Stratix switches have AOPs that enables us to use our Rockwell PLCs to gather...
2,236
Hi, I started my journey with Micro820 and I have to read input status address 10001-10010 from one device via Modbus TCP, everything works fine...
1,198
I'm headed to my shop right now to try an experiment. I'm trying to find out if the PowerFlex 700s can swap control boards and successfully power...
2,575
