Hi and Welcome to the Forum!
I assume when you say "logix", you are referring to a Logix 5000 controller, which uses RSLogix 5000/Studio 5000 software, and not a MicroLogix controller, such as a ML1400, which uses RSLogix 500 software?
The use of both types are supported over Ethernet/IP (ML1400 only for RSLogix 500) with the Kollmorgen AKD
Servo Drives, which have EthernetI/P built in, but the Logix 5000 option is by far the easier to set up and more robust of the two.
Here is the specific PDF for setting up either of the above options with a servo that has built in EthernetI/P:
Kollmorgen AKD EtherNetIP RSLogix Communications Manual EN Rev G FW 1-12
If you are using an AKD
Basic Drive, or older Servo Drive, then Ethernet/IP functionality is not built in. You would need an additional interface module if you want to communicate over Ethernet/IP to your controller. Kollmorgen do not provide such a module themselves, but Imac Motion Control have specific interface modules for converting from older serial com ports on the servos to Ethernet/IP based Logix 5000 controllers.
Here is a link to info on Imac's modules and some useful code and AOIs:
IMAC Kollmorgen Ethernet/IP Servo Module
Here is IMAC's specific PDF for setting up the modules with RSLogix 5000:
Regards,
George
