I am a college student and am having trouble programming my final project. Our project is an automated can crushed and the part I am having trouble programming is a pneumatic robotic arm that will pick the can up and move it onto a belt which feeds into the crusher.
I need to program the arm to run in a continuous sequence such as (raise up, swing left, lower, open claw, etc...). It is wired to my output card and has a total of 9 movements. My instructor said the easiest way to achieve this is through a SQO instruction, but he himself doesn't know how to set it up.
My questions are how do I set up the array? Do I need to use 1 or 2 dimensions? How do I address a certain point on the output card to a certain point within the array?
I have read that maybe MVM and MOV commands might be easier to work with rather than SQO's. If this is true could you give me some basic information on how to get started.
I am using RSLogix 5000 v12 to program it on an AB ControlLogix 1756 system.
