A newbie AOI program question
The Help in Studio 5000 would appear to indicate that the VIS setting can only be changed for AOI instances when using FBD. Contr_Conn mentioned this a bit earlier in the thread. And yes, some of Rockwell's built-in blocks do allow this in Ladder. The Scale instruction was mentioned earlier, but that is an FBD instruction and pretty much all FBDs allow this. The AOI version they offer on their download site doesn't allow that same configurability when in ladder.
Determines whether the parameter is visible on the Ladder Diagram and Function Block Diagram instructions when the Add-On Instruction is called. Right-click the Vis heading to select or deselect all the rows in the column.
If Req is selected, Vis is selected and read-only. The Visible function is not applicable for members of InOut parameters.
If the parameter is not required, the Visible configuration may be overridden for Add-On Instruction called in Function Block Diagrams routines. Overriding the visibility at the instruction call level does not affect the definition configuration.
OG
One that ****es me off to no end is that on Siemens Ladder I can either type a variable on a block input or... connect a ladder network to it. Much better than cross referencing up and down for the instruction instance like Rockwell imposes.
Hello all, I'm a new member here. I've joined as I want to learn about PLC programming. I've got a few questions to begin with. To get me...
37
4,564
Howdy folks. Been doing PLC programming for like 15 years now in LD and ST, but I'm trying to learn SFC now and have a kind of dumb question... I...
1,408
Hello. New to Unity and had a couple quick questions. Can a Modicon M340 output to a small multiline LCD screen and not a full HMI?
964
Good morning, I've had an inverter fail with firmware revision 5.002, the only spare is Rev 7.001, when updating the project with the new...
1,260
Hi all, not sure if this is a "thing" but I was hoping I could find out if there's anyone out here willing to supply me with live training. Phone...
1,100
