Newbie timer question
Narlin
Mar 2010
phoenix
320
Micrologix 1100 TON timer. I want the Preset to be a user OIT input. Software won't accept a variable for the preset? Does that mean that i have to (for example) put a 1 second timer in and run it over and over again until i have counted to the number of seconds that the user sets in place? Is there a easier way?
narlin
Couple of options:
1) Your OIT should be able to address the preset -- obviously we don't know what your OIT is, but, the timer preset would be T4:20.pre Make sure you're doing that format correctly.
2) Alternately, can you write to an integer (e.g. N7:20)? If so, just MOV the integer to the preset in your PLC (MOV n7:20 t4:20.pre)
It is safer (prevents negative presets and CPU faults) to limit check an integer and move it into the preset with one PLC instruction. It can also help keep your HMI addresses in succession which is more efficient than reading/writing data to/from many different files.
Also, with some HMI software, the .pre suffix on the address might have to be input differently. For example, with Crimson 3.0, you would enter T004:0015.01 to access T4:15.pre and T004:0015.02 to access T4:15.acc
Coincidentally, the .1 and .2 delimiters for counter and timer addresses also works with PanelBuilder32.
Learned something.... Thanks Okie!
You're welcome!
I was taking apart someone else's (working) .pba file and saw the .1 reference for his counters' presets a few years ago and thought it was odd. Then working with Crimson, I see they do the same thing too.
Good point, and I have also seen / and . interchanged.
Hello All, I inherited a S7 300 project at work after the previous guy left. I'm completely new to PLCs but have been trying to ramp up for a...
5,863
Hello all, I'm an 'Instrumentation & Control System' final year student. Currently I'm doing my final year project and using PLC (OMRON) as my...
6,942
Hi all, 1. It seems from my reading that timer addresses in Step7 have to be just these certain addresses in order to get the resolution...
3,990
Hello all, I'm a new member here. I've joined as I want to learn about PLC programming. I've got a few questions to begin with. To get me...
37
4,609
Howdy folks. Been doing PLC programming for like 15 years now in LD and ST, but I'm trying to learn SFC now and have a kind of dumb question... I...
1,425
