Noise Filter
Unregistered
Guest
U
1. WHAT IS A NOISE FILTER FOR PLC?
2. wHERE WILL A NOISE FILTER BE INSTALLED IN THE PLC? INPUT / OUTPUT?
3. for example, I have an Omron PLC - CPM1A - 30DCR - A-V1, what is the compatible model of Noise filter that I will acquire?
Thanks,
Alan
You should not need a noise filter on an Omron PLC inputs if you wire correctly to the inputs. Outputs do not require noise filters. Omron processor power supplies are very well protected against industrial noise and I haved NEVER required a noise filter yet.
I would suggest you wire to the inputs using screened cable if noise may be a problem. Make absolutely sure you do not run anything else in the cable and make sure you wire the inputs according to the Omron manual for the PLC.
Please join the forum and do not remain anonymous. I normally do not reply to anonymous people.
What is the purpose of noise filtering in the power input side of plc. any suggestion/recommended noise filter for GE brand of plc. Thanks
1,482
Hello, I am running a AMCI SD4840 Stepper Motor drive system with Allen Bradley CompactLogix. Every now and then when a 480VAC motor kicks in on...
594
Hello Everyone, I hope we are all well. I have an L36ERM with a 1769-OF8C/a driving a 5HP Power Flex 523 speed reference 4-20 mA. With the...
1,839
Good Morning , We have a new Fortress Stealth Metal Detector. About 30' away we have a machine with motors and solenoids on it , Whenever...
2,202
I don't want to state the obvious to those in the know, but I wasn't in the know. Apparently, the way dc switching power supplies work, they are...
2,495
