Hi. I've artfully avoided Siemens for a whole decade but now it's inescapable. I'm trying to figure out what software is needed to support new-ish (2017) machinery containing Siemens Microbox PC IPC427D (6AG4140-3EL04-0HN0), Flat Panel IFP1500 (6AV7863-2TB10-0AA0), ET200SP I/O, and ET200M I/O. And how it all works together. I have an old laptop with Step7 5.5 SP1 and WinCC Flexible 2005. I doubt that's going to help me.
It's my understanding that the MicroBox PC runs a software PLC* within(?) or beside(?) the Windows Embedded operating system, independent of the operating system, and also runs WinCC HMI runtime** for the flat panel touchscreen. So the HMI is not programmed physically separately from the PLC. Is that correct?
*per the P/N [ N ], the SW PLC is WinAC RTX2010 F (Failsafe)?
**per the P/N, "Software Configuration preinstalled Bundles contains WinCC RT Advanced V13 / Professional V13"
So now I wonder, do you still program the SW PLC within the Microbox, from a separate laptop with Siemens programming software installed? Or do you just connect a keyboard and monitor to the Microbox and program it directly? I assume it's still via laptop, but just want to confirm.
It's my understanding that WinAC RTX2010 is still programmed via Step 7, so I won't need to purchase the new TIA Portal software. Is that correct? Can I update my old Step7 5.5 to talk to this setup?
I've tried (and still trying) to answer my own questions with Siemens documentation, but... and this is a large part of the reason I avoided it so long... The documentation, or the structure of it, is not at all intuitive to me. There are plenty of high-level resources like marketing brochures (totally unhelpful) and low-level ultra-technical documents, but I can't find anything in the middle, or anything that bridges the gaps between products and explains how they work together. I don't expect to be spoon fed a bunch of answers to a bunch of questions here, but if someone could just link a Siemens doc that would be helpful for someone asking the kind of questions I'm asking, I would greatly appreciate it.
