NOP in STL - Step7
Pete.S.
Mar 2016
Fl
463
Hi guys!
I was wondering why I've seen some guys put a lot of NOP in their STL code.
For example:
Code:
CALL FC4
NOP 0
What is the purpose of this? NOP doesn't do anything.
Thanks,
Pete
Also if you have a very big FBD/LAD network. Switching it to stl and adding NOP 0 to the bottom will keep it in STL when you switch back to FBD/LAD. This is useful if you have dozons of or/and ports. IE:
Code:
A bla1
O bla2
O bla99
O bla100
= blop
NOP 0
Makes sense. But if was compatible with both and you wanted it to show up default as STL (or LAD) would it be possible to change that?
In block properties there are "Created in Language" but it's read only...
As far as I know, as long as the logic is compatible with both, it will open as whatever you used last.
You can switch between languages when you open the block. View>LAD/STL/FBD.
Or these shortcuts Ctrl+1 = LAD ,Ctrl+2 = STL, Ctrl+3 = FBD
Thats true, The block will display the last language which it was saved in. Networks that are not possible to be displayed in FBD/LAD will default to STL.
Sidenote: Always switch to FBD/LAD when adding variables to the temp area of a FB. When in STL it could cause problems with the local addres the auto generated stuff of the FBD/LAD networks.
^I want to emphasize this. It's super important. Step 7 sometimes warns you about it, but it is really easy to ignore.
That's the gotcha. You have to SAVE the block or it will always open the same way regardless if you change the language.
Is there an equivalent Rockwell PLC NOP instruction that is available for the M340 M580 Schneider PLC? Thanks,
2,724
Good evening , I was looking thru some Rockwell Automation programs , and took notice in some programs , UDT’s , AOI’s , etc. the NOP...
3,185
I have read the Instruction help on this. I am still not clear or sure on why this would even be used. I see this a lot on Rung 0 inside of the...
4,493
Anyone know if there is an equivalent to the NOP instruction in Logix 500? I like to use them in my Logix 5000 for program organization and...
4,438
Good afternoon to all Could you pls to have any advise for the following trouble: Power management system: SIMOS PMA 71 QUOTE The problem on the...
2,298
