O/T Communications:
gbradley
Apr 2002
Corona, Ca.
1,637
Off topic, Communications, I am the worst at this.
I was trying to read serial data from a Cognex camera, and I don’t seem to be able to view it.
I tried swapping Rx and Tx, but nothing...
I wanted to make sure that the USB to serial Com port is working, on my laptop so I ran Hyperterminal, and plugged a Loopback connector to my com port.
The Echo came back good, so I am sure that the Com port is working.
What I want is to be absolutely positive that I can get a signal from a known source, so I thought that I can connect two laptops together.
Is there a way to connect two computers through serial ports using hyperterminal, or RealTerm?
Do you need a crossover cable between them?
I've been dealin with some intermittent CIP explicit messaging issues. I tried reducing the amount of small MSG instructions and converted them to...
18
408
Hello, I'm trying to delve a little into rs-485 communications for a couple projects of mine. Until now I've been using a delta vfd and a delta...
131
Sorry if this has been asked before, and apologies if this seems like a trivial issue, but I am new to Beckhoff and have been banging my head...
172
I have a curious question and I can't seem to find any information on it. I'm hoping I'm just overlooking something simple. I have 4 machines...
474
Multiple PLCs in our plant communicate using either MSG instructions or Produce/Consume. Is there an industry best practice for documenting this...
778
