OEM PLC / microprocessor with ladder programming
johnyu
Aug 2006
Melbourne
I'm looking for a board with 1-2 analogue inputs, 10 inputs, 6 relay outputs, power supply 6-12V, no enclosure, so I can mount it inside my own box, and it has to be cheap, less than $80, $50 would be perfect because i want to get 100+ of those boards, is there such a thing around?
here's some of my thoughts, an OEM plc board which provides all of the above and meets the cost,
or
a microprocessor e.g. PIC, plus a relay board, input, ADC module, i don't care if the board doesn't allow direct programming, i.e. I can flash the chip using a programmer. Preferably can be programmed using ladder logic, I only tried embedded programming once, and i like to avoid it. ideally the hardware should be easy to setup without to much tinkering.
What do you recommend (plc vs microprocessor) and what product?
Hello, I'm a novice PLC user but advanced Excel VBA user. I've created a program to capture and email data from our PLC. The capture happens...
21
3,882
I've had a Danfoss OEM drive come in from an Ingersol compressor. It is essentially an FC302 but the OEM part is IR302. the drive appears to be...
386
As I understand it, Codesys is the foundation for many different OEM branded HMI software packages. What are the advantages and disadvantages of...
1,651
Can anyone share the hardware/software in integrating Radio-frequency identification (RFID) security on a plant floor's OEM machine HMI's? I...
2,976
Hi Guys, I need some help with a machine that has an SLC 5/04 communicating with a wonderware panel over DH485. I can monitor the logic while the...
3,361
