OFF Topic - 0.1mSec Timer
chavak
Jul 2002
750
Any recommendation for an external timer with solid state output having a resolution of 0.1 millisecond.
Thankyou
Best Regards
____________
Wow! What kind of application do you need that for? Plan on generating a clock for a CPU or something?
chavak said:
Thankyou
Best Regards
____________
I don't know what the OP needs one for, but I used one where I needed .002 resolution for the operator to introduce a delay on energising a indexing clutch brake combo. There was no HMI available plus I had a 40ms scan time on the PLC any way. When the operator first told me about the concept I thought he was full of **** ! It worked so well I added 1 to every machine (that had a simular function) that I came across in my travels.
Hi
Allscot,
I did check omron site earlier, the timers they offer is upto 1 millisecond resolution, I am in need for 0.1 millisec.
surferb,
The application is for a constant amount spray (atomizing) of liquid. The end user is particular about the CPK on the amound dispensed.
I'm still searching.......
Thankyou
_______
This application to me sounds like spray is is atomised when a solenoid operates.
If you need a solenoid to operate then I feel 0.1 sec if an extremely fast operation and you are wanting it to operate 1000 times faster, I think you need to do the maths again.
This is the motor nameplate from one of the powder hoist motors on the USS Texas an older generation battle ship, built in 1911-1914 ish. The...
295
Totally off topic, but strange observation. I purchased a few cisco ethernet switches off of ebay some years ago. They are part of a home lab...
2,080
Good morning, Please excuse me if this is too off topic here, but it is a programmable controller of sort. I have an Omron ES100P temperature...
2,342
Which way is up and what's that strange looking bug? I was trying to login to micro_cr*p team_Shi* and it wouldn't let me because I exhibited...
2,706
Hi folks, I have a hydraulically driven rake in a clarifier that rotates at about .18 rpm. When there is a process upset, the bed of the...
3,732
