Offset and gain in of FX analog modules
farooq.gill
Oct 2014
Lala Land
I want to know when do we need to use offset and gain in analog modules of FX series. I mean I am not clear what are offset and gain. Please tell me a little about it with example. thanks
Plus Do we need scaled values of analog input just to show on the HMI??
You will need to set them when you have an error in your analogue input/output measurement
Have you read the manual, its all explained in there with examples ?
You haven't told us if this is and AD or DA unit but this would be true of a DA unit
Gain value: Analog output value when the digital input is 1,000
Offset value: Analog output value when the digital input is 0
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
107
Hi all! I need to adjust Offset and Gain on Analoge out card A62DA... Will the CPU (mitsubishi A1) stop when short circuiting 1 & 2 (Test)?? Will...
1,705
Anyone have problems with the absolute offset of an axis controlled by a 1756-M02AS being erased and/or being a large number that doesn’t relate...
1,336
I'm trying to offset Main CIP (Master) for other slaves (Drives). I have 360 Rotary Scaling. For the MAPC I'm using "(360.0 +...
1,175
Hello, Bit of background on the job I am carrying out. Old Setup: Data from CPU ----> Historian ME module -----> Historian SE V3.0 Windows...
1,244
