Offshore Fire & Gas System (Autronica) problem
kevin-marcel
May 2010
WD
Guys,
I'm having a problem with Autronica Autrosafe system. It is a rig fire & gas system, for accomadations. This system is freezing almost twice a day. I think it has a memory problem, but I’m having problems for getting the diagnostics.
Has anyone worked with this system before? I want to do some tests before calling the vendor.:(
Thanks,
Kevin
"Error:Could not initialise Ssio" message on Autrosafe BS-310
Our Fire alarm system controled by Autrosafe BS-310 control panel.[FONT=&quot]After applying the power supply autrosafe program could not load, [/FONT][FONT=&quot]on the monitor appears counter, after 20 sec continuously beep, system fault indicator and after approximately 2 min appears message: “Error: Could not initialize Ssio”, who knows what that means. [/FONT]
Hello, Looking at quoting a system with a 100hp motor for offshore use. Motor is only used a few times a month. I’m thinking I might need to...
2,210
And especially oil rig of different types? I´m thinking of trying some new branch out, someone here that have worked with design of systems to...
2,999
To replace the pneumatic/hydraulic ESD/FSD panels on unmanned oil/gas well platforms with PLC based system which SIL level (as per IEC61508) is...
2,830
Johnny Mnemonic
J
New to the ABpoint IO and have some experience with plcs but not that much. Anyway my question is why are these output cards flashing red? I am...
1,133
Hi Can anyone give us the name and part number of programming cable for AM1000 fire and gas panel. Thanks
1,014
