Omron 3G3MV Inverter Parameter setting for pulse train
baba1511
Apr 2005
19
Hello all
Please who can give me the n01 to n179 parameter setting for sysdrive 3G3MV Inverter to run in pulse train control. All contribution are welcome.
You set N004 to parameter 5 to enable the pulse train control terminal. Terminal RP is the signal input referenced to FC the common.
Parameter N149 is the scaling control for the pulse frequency.
Thanks I tried but it never work, I still need more help but I will check if there is open circuit.
Regards
please i need a help,i have an ac motor conveyor replaced,which is controlled by omron 3g3mv inverter.how can i change the frequency of this...
1,666
Hi, I need to pull the settings from an omron 3G3MV inverter using cx drive. I've ordered the relevant cable but does anyone know the pin outs. I...
18
7,359
currently operating machine that is currently using a CJ1m-CPU22 this sends an analog output to FR-FC inputs on the drive then links the next...
6,448
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
43
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
182
