Omron C200H programming cable.
ToddM
Oct 2004
Cascade Va.
106
Hi Folks, I hope somebody can help me. I work mostly with Allen Bradly PLC's a few GE fanuc and siemens Step 7s. But the company I work for has just installed some used sample machines with Omron C200H/cpu01 PLCs. We have a copy of Syswin 3.4 for the only other Omron PLC we have.It's my understanding that I can still use this software to communicate to these C200H PLCs and all I have to do is convert the programs. What type cable do I need to communicate with and where do I plug into the processor? The only connections I see are a minature D shell with 20 pins and another long connector that almost looks like a printer port. I also have a LK201-V1 RS232C module in the rack but it's being used for something else. Can I put another one of these in the rack? And if I can, can I network these machines together using this module.Any help or info would be apprecated. Thanks ToddM
There's currently two Compiler programs for the Omron:
Syswin and CX-Programmer.
CX-Programmer can read and convert Syswin files into CX-P files.
I'm not sure if Syswin can read CX-P, would guess not though.
Once Syswin files converted they cannot be reversed back to Syswin.
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
715
In order to upgrade a control unit, we need to backup program of an omron C200H CPU01 with host link LK202-V1 that has RS422 D9 Connector. Please...
629
The logic seemed to convert nicely, and I had to make changes to the addresses for my AD and DA and 32-point input cards. The current problem is...
1,037
I am trying to display some scaled analog input values on a C-more Micro terminal, from an older C200H Omron PLC. The addresses appear to simply...
2,181
I have a customer with the Omron C200H that occasionally will start flashing the alarm light and the machine stops. They say they can power down...
3,054
