Omron C200H to C-More
LumberJack818
Dec 2006
New Jersey
Let me start with I don't have a lot of experience with this so I apologize if this is something dumb.
I need to replace an obsolete HMI on one of our older machines running a Omron C200H. I purchased a 6" C-More touch panel and I am connecting it through the LK201 communications module. I am having trouble getting the panel to connect with the PLC. I am using the automation direct cable and all the comm settings appear to be correct(9600, Even, 7, 2). I can connect to the PLC using CX-Programmer without any trouble but with the panel I get no response from the PLC. There seams to be communications from the panel because the receive light flashes on the LK201 but I get no response.
Any help, advice or thoughts would be greatly appreciated.
Are you using the same cable to connect the panel and CX-Programmer?
What driver are you using for the panel?
Not familiar with the C-More panels, but this is where I would start.
Hope this helps.
I am using 2 different cables to communicate. The one I use for CX-Programmer is homemade and the one for the C-More Panel is a purchased cable from automation direct.
The comm protocol for the C200H is host link.
Thanks for the response
I am trying to display some scaled analog input values on a C-more Micro terminal, from an older C200H Omron PLC. The addresses appear to simply...
2,180
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
714
In order to upgrade a control unit, we need to backup program of an omron C200H CPU01 with host link LK202-V1 that has RS422 D9 Connector. Please...
629
The logic seemed to convert nicely, and I had to make changes to the addresses for my AD and DA and 32-point input cards. The current problem is...
1,037
I have a customer with the Omron C200H that occasionally will start flashing the alarm light and the machine stops. They say they can power down...
3,049
