Omron C200H
Omron C200H requires a Host Link Module.
There were two different types, one that mounts to the front of the cpu, one that mounts in the I/O backplane.
3G2A6-LK201(-V1) is the part number for the cpu mount unit.
C200H-LK201 is the part number for the backplane mount type.
You may be able to find one on ebay.
Cable is a standard null modem cable.
Host link connector is a DB25.
Omron offers a solution. Part number C200H-IP007.
This also requires cable part number CQM1-CIF02.
Total price is $3125.00 US dollars.
C200H was discontinued in 2001.
Hope this will help.
Thank you so much for your help :D
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
715
In order to upgrade a control unit, we need to backup program of an omron C200H CPU01 with host link LK202-V1 that has RS422 D9 Connector. Please...
629
The logic seemed to convert nicely, and I had to make changes to the addresses for my AD and DA and 32-point input cards. The current problem is...
1,037
I am trying to display some scaled analog input values on a C-more Micro terminal, from an older C200H Omron PLC. The addresses appear to simply...
2,181
I have a customer with the Omron C200H that occasionally will start flashing the alarm light and the machine stops. They say they can power down...
3,054
