Omron CJ1M CPU 13 communication.. urgent help pleased
Thanks again
I want to do the upload for the first time and I work with the usb serial adapter in the following order.
1: I select the plc type through the workplace, ie cj1, cpu12
2: In the networke type section, select the nv-thru connection type
3: select the work online and then ok
But with the usb to serial adapter I have, I can not communicate with plc.
What cable do you think I should buy to connect peripheral cable or usb to serial adapter omron factory?
Hi I have a plc omron CJ1M connected to a HMI this is a reconditioned panel in which this plc is connected. But the touch screen of the HMI is not...
3,585
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
255
hi dear all hope you all are fine I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications...
171
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
167
i have been trying to connect to omron cj1m via peripheral port(USB to Serial), but there isn't any sign to show that it has connected, so am...
322
