Omron CJ1M/ETN21 VPN access
shaulapto
Feb 2004
Raanana,Israel
53
I'm trying to configure the Omron ETN21 ethernet module to access it trough VPN without success.
I am able to connect to other PLC's in the same network and also to connect to the moudule locally but not remotely trough VPN.
I know the problem could be in the routing table but it is not so clear to me how to arrange it.
May be some of you have done this connection before and could help.
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
256
hi dear all hope you all are fine I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications...
174
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
167
i have been trying to connect to omron cj1m via peripheral port(USB to Serial), but there isn't any sign to show that it has connected, so am...
323
Has anyone encountered an error code 31 on an omron cj1m-cpu12? This error code is not covered in PLC manual.
523
