OMRON CJ1's Ethernet Networking problems
castro
Jul 2004
Brampton, Canada
Currently we have setup a CJ1H-H CPU65 with two CJ1W-ETN11 units (ethernet units) and a CLK21 unit (controller link unit). It is connected via a wired Ethernet connection to a PC and to a CJ1G-H CPU42 (with Ethernet and controller link units) via a wireless Ethernet connection through two LINKSYS 2.4 GHz Ethernet bridges, one at each side of the connection. Communication between the two PLC's is okay. However, we have started testing with parts of the machine which involve 48 other wireless devices and in the future there will be 120. We have had communication problems. To rule out or to confirm that an overload of the wireless network is causing the communication problems between the two PLC's, I have been trying to replace the wireless connection with a wired connection with no success.
I used a cat 5e crossover Ethernet cable from the CJ1H-H PLC to a switch and from the switch to the CJ1G-H PLC, I used a cat 5e straight cable. I would appreciate your help regarding this issue, as well as any suggestions regarding other networking strategies to oercome this problem.
"We have had comunnication problems" means we have had interuptions in data transfer between the two PLC's. This has brought inpredictable behaviour in the machine.
There have been quite a few discussions in the last few months about wireless setups.... You could probably dig up quite a lot of information by doing a search for "wireless".
This one is around. I answered elsewhere that switches normally use crossover cables in and out and hubs use straight cables as the crossover is done in the hub. Have had no response. Do not know whether this was the problem or not.
Would be nice to know.
Currently we have setup a CJ1H-H CPU65 with two CJ1W-ETN11 units (ethernet units) and a CLK21 unit (controller link unit). It is connected via a...
11,768
Hey all, If I manually set a stack (not using the first scan bit) does the stack persist after an event like a power cycle or download, as long...
1,030
Has anyone done a migration from CJ1 platform to an NJ/NX platform? Is there a program conversion utility for Sysmac Studio similar to Rockwell's...
1,179
Hello everyone, We are using Cimplicty in our company to communicate with some CH200 PLC's and i've managed to connect some S7-1200 PLC's. Now...
2,391
Dear my freind i want to know if there is any way to open a protected plc program (omron cj1) , without clearing memory . Thank you again & ciao .
1,967
