Omron cp1h fins 2108 error after plc power down
patrickser
Apr 2012
Oklahoma City
I have a CP1H with a CIF41 ethernet module. Only one PLC is on the network and is the only device that should be receiving commands. I am able to send commands and get responses back fine from both my custom script and a FINS tools I downloaded. The problem starts if I power off the PLC. After the PLC powers off and starts back up any attempt to send a command to the PLC gets a response of my command and then 2108. For example if I wanted to send 0501 the response would be along the likes of 05012108. The FINS program however can send to it fine still. The only way to be able to send commands and get responses again from my script is to connect to it from CX programmer and then disconnect. It is like it resets the socket connection or something.
Any ideas would be of the utmost help. If anymore information is needed let me know.
Here is some diagnostic information in picture form
Here is the current configuration of the ethernet module
Here is the current configuration of the fins testing program that works fine no matter what.
Here is a the packet that sends the read command from my script in a network analyzer
Here is the response packet from the read command issued by my script
Here is the packet that sends the command from the FINS testing program that works regardless if the PLC was powered down
Here is the response packet from the FINS testing program issuing the command
I am trying to figure out a way to dynamically change PLC programs through the FINS protocol (specifically the Program Area /Clear/Read/Write...
2,911
Hi all, I have to say first that I have no experience with Omron devices, but here's the challenge that I'm facing. I have an Omron CP1H...
1,709
I have a question about SET instruction in Cx-programmer. When condition goes true it is supposed to give value 1. But, my controller is giving 0...
24
2,289
Hello Sir/Ma'am, Hope you and your family are safe in this Covin-19 Pandemic. One of my client have a machine in their ceramic industry which...
2,621
Hi, I recently had to buy a batch of new electrical components containing 10 PLC Omron Type (CP1H-X40DRA) Apparently stored in store (to be used...
3,558
