Omron CP1H FINS Program Area Write Command
patrickser
Apr 2012
Oklahoma City
I am trying to figure out a way to dynamically change PLC programs through the FINS protocol (specifically the Program Area /Clear/Read/Write commands. I found the command information here: http://goo.gl/lhlv6 in section 5-3-11. I am trying to find an example of this command to get started with.
I am wanting to do this to eliminate CX-Programmer from being needed to upload new programs to the PLC. The intended result is to be able to use CX-Programmer only to create the ladder logic files and than use a FINS protocol script to upload them to a PLC.
Any help or advice would be greatly appreciated. I am new to the PLC world.
I agree = Why ?
I have done some CP1H programming, and used a USB connection to download programs. What do you expect to gain with FINS ?
Why do you need to 'dynamically change' the program ? Won't conditional branches work instead ?
I use dip switch 6 on the CP1H to select between two programs,
this turns ON/OFF A395.12. Then turn desired tasks on/off using [TKON]/[TKOF]. Remember to uncheck "Operation Start" in the tasks you wish to control.
Alternately why not use the CP1H Memory Cassette.
KISS
My 2 cents.
I have a CP1H with a CIF41 ethernet module. Only one PLC is on the network and is the only device that should be receiving commands. I am able to...
4,749
Hi all, I have to say first that I have no experience with Omron devices, but here's the challenge that I'm facing. I have an Omron CP1H...
1,709
I have a question about SET instruction in Cx-programmer. When condition goes true it is supposed to give value 1. But, my controller is giving 0...
24
2,289
Hello Sir/Ma'am, Hope you and your family are safe in this Covin-19 Pandemic. One of my client have a machine in their ceramic industry which...
2,618
Hi, I recently had to buy a batch of new electrical components containing 10 PLC Omron Type (CP1H-X40DRA) Apparently stored in store (to be used...
3,555
