Omron Cp1W-DAB21V Option Board Error
Wiresplus
Sep 2021
Auckland
17
Hello,
I have a CP1H-XA4001 PLC, with a CP1W-DAB21V option board.
The moment I insert the board, the PLC goes into Error.
I set the dip switch to auto - same result.
I went into settings, and set serial port 1 as 115200 and ToolBus.. Still no change
Has anyone any experience with these and can point me in the right direction?🤞🏻
It displays the PLC error light, then about 3 seconds or less later the DAB error light. The display on the PLC says D.1.[flashes]0.0.
Hi all, This is my first post on here, hopefully you can all help. I'm very new to PLC's and have been given a project at work that's currently...
3,743
There have 2 different value in configuration output 2 on Omron CP1W-DA041 manual which one the correct? thanks for your time.
2,324
Ok I have an CP1W-C1F41 Ethernet Comm module added to my CP1L PLC. What I am trying to do is set it up (IP address etc). I can not find a manual...
2,632
Brand new to Omron My supplier speced CP1H-XA490DT1-D CPU with 2 CP1W-20EDT1 expansion modules Using CX One Lite I can't select the CP1W units...
3,204
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
150
