omron cpm1 peripheral port to Rs232 wiring cct
Robfav
Nov 2006
Melbourne
Is it possible to have rs232 connection to peripheral port of omron cpm1 plc to be used for uploading and downloading of program and if so does anyone have wiring diagram .
thanks Robert
The CPM1/CPM1A only has a peripheral port connector.
The CPM1-CIF01 is an adapter unit, DB9 on the front with a short cord with the peripheral connector to plug into the plc.
Hope this will help
Hello and thanks for the reply.
So ,if it is only an adaptor does anyone have the pinout of this unit going back to the peripheral plug like a one to one connection from db9 to the peripheral plug for omron cpm1 plc ?
Thanks for your replies.
I suspected that they probably use some gate or dongle in between the connections but wasn't to sure.
Kind regards
Robert
It is a Host Link/NT Link chip as far as I know because you can switch between either.
I'm taking some time today to learn how to edit a customer's Omron PLC program. My customer has a machine that is used infrequently during the...
2,857
Hello there! i need some help regarding omron plc the CJ1M and CPM1, do they have the same software and connecting cable? and which of the two is...
2,744
Today i try do upload the program, but when click ok the programe tell me the program is protect, i need the pasword but i forgeret,
1,372
Hy, guys I need to know how make contactor retencion? For examplo If i push switch for input 00 and active 00 out but i need how make if i push...
2,784
I have software fore omron cpm1, this software kork whith cpm2. I need help guys tank you.
2,521
