OMRON CPU Communications
zakir
Jun 2010
dhaka
24
Dear all
i am having some problem with the omron plc communication system. in our factory's control room we have 7 CJ1M and 2 CS1G CPU. so if we want to troubleshoot we just connect the CPU with a serial RS-232 cable with the Dekstop computer. so it is a problem for us check other CPU at the same time unless we disconnect the cable and put it to another.
now i want to connect these 7 CJ1M and 2 CS1G CPUs with the dekstop computer at the same time. in that case i dont have to disconnect the cable everytime. and i think i have do it if i want to make a HMI system for our process. i am using CX-Supervisor software to make the HMI.
please let me know how i make the connection of all these CPUs with the dekstop computer.o_O
Get some ethernetmoduls, and make the connection!
It`s fast and give you easy support at the same time
the CX-Supervisor is running...
BjarkeSS
What about using ControllerLink (CJ1W-CLK21-V1).
It is a proprietary network, but would be less expensive that ETN21 modules.
You can still connect to one serial port and access the other cpu's over ControllerLink.
Just a thought.
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
218
Project involves updating a ~23 year old controller (C200HX CPU64). The HMI is a windows NT machine with the gui done with Delphi 5 (Pascal)...
1,100
I want to take backup from Omron MC04 CPU. I connected CPU online with "Work Online/Offline" option & succeed. But bit confused about available...
488
Hi, I have an Omron PLC (CQM1H-61CPU) connected to an Omron HMI (NT631C). In order to connect a PC to them, I want to know: 1- Is the cable...
861
Hi Guys, I am trying to read data from Omron CP2E CPU from my Mitsubishi RJ71EN71 with Simple CPU Communication Function. Suppose it was using...
1,810
