Omron CQM1H-CPU 51
isteak007
May 2009
NewYork
216
I have one Omron CQM1H-CPU 51 with a analog module CQM1H-MAB42
MAB42 module install in inner slot of CPU.
Now this analog module channel 1-- Voltage Input 1, Pin 7 is faulty. so i would like to use the Voltage Input 4, Pin 1.
but i am new in Omron PLC, so i have no idea how the analog address written in Cx- Programmer.
Please help...
You will need to review two manuals for the information.
W363 manual documents the wiring of the connector.
W364 manual explains programming and addressing.
Hope this will help.
I can't find DM6611 Word in my program?
so how the analog address written in the program? o_O
Attached Program file
DM6611 is in the PLC Setup area and can only be modified using a programming device (handheld programmer or software).
The analog input values are located in 232 - 235.
Analog output values would be written to 236 or 237.
Thank You Very Much for your help.(y)
Hi, I have an Omron PLC (CQM1H-61CPU) connected to an Omron HMI (NT631C). In order to connect a PC to them, I want to know: 1- Is the cable...
873
We have one Omron Device CQM model 21 and changing it by Device CQM1H model 21 when we downloading converted application into CQM1H then we got...
1,783
Hello Guys. I am having a problem with my omron cqm1h cpu 51 and i need help from you over there. The problem is that every time i power the...
6,985
hi all i have a omron cqm1h-cpu51 and I am not that fimilar with tis plc the problem that I need to backup the program on the plc to pc but I do...
2,125
Hello all of you!!! I have problem with program for concrete plant(CQM1H CPU 51,ID212 x1,OC222 x2,OC224 x1,AD042 x2) and need help from you...
4,445
