OMRON CQM1H-CPU21 communciation with VB.net
tkteh
Sep 2011
Malacca
I am new here, and hope if there is any things I done wrongly, please feel free to tell me. Thanks in advance.
Currently, I am deal with PLC OMRON CQM1H-CPU21, I need to use this PLC transmit data to vb.net, and show it on my laptop screen.
Now I able to online by using CX-Programmer, means my cable and serial converter is doing good job. But, when I online by using VB application, the COM Port indicator at PLC is not blinking, means no connection? (when use cx-programmer, it do blink).
Secondly, anyone got sample of the protocol and code of VB2008 or VB.net for the transmission of data from PCL to PC, I just need 1 way flow, that is from PLC to PC, to read the I/O status on PLC by using PC software(vb..etc..)
Thanks in advance.
best Regards,
teh
The following link is for a sample HostLink VB program.
You should be able to update it to work for your application.
http://forums.mrplc.com/index.php?app=downloads&showfile=62
Hope this helps.
Hi, I had try the application and it do works, but I not really understand with the response of PLC, I sent choose RD1000 0001, and at the "To PLC" text box, it appear as @00RD1000000156*
and "From PLC" it appear @00RD000000056*, what is this means?
I suppose to read the data at DM1000 for 1 words for now, will increase later on, but what is this codes means?
Sorry for bad english >.<
Regards.
teh
Hello, i have a omron plc with cqm1h cpu, and is protected by um read password i need any program to crack it lik xtal, plc backup tool v6 with...
1,075
Hi. I work for an industrial machinery merchant so we have to try to get uploads from all sorts of different PLCs & HMIs. Our latest victim is an...
5,640
Hi, i have been given the task of measurring temperatues of a certain cooking chamber in my factory...they have a plc omron cqm1h-cpu21. My boss...
2,650
I want to download the program to the PLC Omron CQM1H-CPU21 using RS232, but an error message appears Dip Switch settings are wrong, therefore how...
7,774
Attach is the program that i uploaded from the PLC after it got underwater from typhoon. Can anyone verify if its corrupted and can't be...
2,134
