Omron CS1G-CPU 42H help...
jcintron
Jul 2009
Florida
I have a little project and need some ideas... here's what I need to do:
*I have 5 push buttons and 5 lights independent from the push buttons.
*When enabled, the 1st light will turn on and a timer will start counting.
*You need to press the 1st push button before the time expires.
When pressed the light will turn off, the next light will lit and the timer will reset and start counting.
*The process will continue until all the push buttons are pressed.
*The cycle is disabled.
**If the push button is not pressed in the specified time the process stops and a bit is set to indicate the process has failed.
any ideas...???
I wish i was still in school...!!! ;) I'm not very familiar with PLC programming just some minor maintenance and monitoring. Do you have anything I can use?
I'm extremely new to PLC's and am having a very frustrating time trying to figure out why my computer isn't communicating with the PLC. I keep...
3,273
I was called out to a site today that I had never been to before. They have an Omron CS1G-CPU43H that was communicating to a NT21-ST121B-E HMI via...
1,458
I am working on a project and our Omron HMI looks for an address to set of an event in the log. example address is 1234.12 However in the PLC...
1,265
Hi all, I just had a question about the CS1G CPU43 and a on a time restraint. I have read the manual and found that to connect to this I need a...
4,049
Hello, I am fairly new to PLCs and have little experience with them so I thought if anyone here could help it would be great. The project that I...
2,357
