Omron HMI - how to upload and decompile several screens on the same hub
Jim_cz
Sep 2011
Sydney
25
I'm trying to upload and decompile 2 screens on the same Ethernet hub. After I successfully uploaded and saved both .pkg files, I selected them in the decompile window and set the path for the .nbp file I got an error message "PKG file is not generated by the same project and same compile, unable to decompile.
Could someone give me a hint what I'm doing wrong? Thanks.
Have never seen that before but I normally do all that stuff via USB and save separate files - works fine.
Do you mean that you use a USB stick to save the .pkg files at each HMI (that were "built" in one project) and then you follow the same procedure as I described? (select them in that decompile window, set the path and hit the decompile button...). I'll try it on Monday. But it would be more efficient if I could do it online.
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
292
I have an Omron CQM1H-CPU21 and a NS8-TV00B-V1, I have followed the manufacturer's spec on how to set this up and all I got is the HMI is trying...
889
Hey everyone, I'm new to this type of HMI and I have a couple of questions. 1) I'm creating a screen with text on it and base font is "DFNB-EN"...
423
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,211
Hi all, I have to say first that I have no experience with Omron devices, but here's the challenge that I'm facing. I have an Omron CP1H...
1,709
